[GRASS-dev] [GRASS GIS] #3091: The RUN_GISBASE variable is not set correctly on FreeBSD
trac at osgeo.org
Fri Aug 4 02:49:13 PDT 2017
Reporter: pieside | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.2.2
Component: Default | Version: 7.0.4
Resolution: fixed | Keywords: FreeBSD
CPU: x86-64 | Platform: Other Unix
Changes (by neteler):
* status: new => closed
* resolution: => fixed
* milestone: 7.0.6 => 7.2.2
Comment:
Replying to [comment:5 lbartoletti]:
> Hi,
> You can close this tickets, we have
[https://trac.osgeo.org/grass/ticket/2940 patched files] for FreeBSD.
... solved in #2940, closing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3091#comment:6>
