[GRASS-dev] OGR SQLite question
Markus Neteler
neteler at osgeo.org
Fri Aug 4 02:56:12 PDT 2017
On Fri, Aug 4, 2017 at 11:51 AM, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> On 29/07/17 17:59, Michael Barton wrote:
>> The db.out.ogr manual states for the input argument:
>> input=name [required]
>> GRASS table name
>> Or data source for direct OGR access
>> How do you specify the name of a table in the GRASS sqlite.db that is not
>> linked to vector objects?
> Probably the manual could do with an update to reflect the fact that it only
> works for existing maps. Maybe the input parameter should be renamed to
> 'map' ?
IMHO no - it refers to a *table*, not a map (the db.* commands have
generally no idea about maps but only about tables).
Markus
