[GRASS-dev] Extract vector features from external PostGIS layer without building topology
nik at nikosalexandris.net nik at nikosalexandris.net
Sun Aug 6 03:09:21 PDT 2017
À Dimanche 6 août 2017, Martin Landa a écrit :
> Hi,
> 2017-08-06 8:38 GMT+02:00 Nikos Alexandris <nik at nikosalexandris.net>:
> > I am looking for a confirmation that the following is _not_ possible:
> > v.external -b input="PG:host=somehost user=someuser dbname=somepgdb"
> > layer=somemaplayer
> > then
> > v.extract input=somemaplayer output=somemaplayer_extract where="some sql
> > query"
> currently `v.extract` requires topology [1]. It would be possible to
> modify it in order to operate also on level 1 (no topology). At least
> for points it would make sense. For areas you always need topology
> built. Ma
> [1] https://trac.osgeo.org/grass/browser/grass/trunk/vector/v.extract/main.c#L188
Than you Martin,
N
