[GRASS-dev] [release planning] GRASS GIS 7.2.2
Moritz Lennert mlennert at club.worldonline.be
Wed Aug 9 07:37:02 PDT 2017
On 04/08/17 12:04, Martin Landa wrote:
> 2017-08-04 11:37 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
>> r71253 dbmi_base lib: add missing arg type
>> r71191 lidarlib: free structs
>> They are not backport yet in case they should be.
> I think so, done in r71323-4. Ma
As can be seen from [1], there is confusion about v.in.ogr syntax for
importing PostGIS layers. This was modified in May (r71093/r71096) to
correspond to ogr syntax. The man page still has other info, however.
IIUC, in the current (trunk and release72) version, this is enough to
import a layer:
v.in.ogr input="PG:host=localhost dbname=postgis user=postgres"
layer=polymap \
output=polygons type=boundary,centroid
and with schema:
layer=schema.polymap \
I'm not sure if any of the info in the "Default connection settings as
datasource (PostgreSQL only)" section of the man page is still valid. If
not, I suggest to erase the entire section and add an example with a
schema into the "PostGIS tables" section.
Martin, any comments ?
Moritz
[1] https://lists.osgeo.org/pipermail/grass-user/2017-August/076804.html
