[GRASS-dev] [GRASS GIS] #3395: t.rast.extract : encoding error
trac at osgeo.org
Thu Aug 10 07:16:10 PDT 2017
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Temporal | Version: svn-trunk
Keywords: t.rast.extract encoding | CPU: Unspecified
Platform: Unspecified |
And here's the next (after #3392, #3393, and #3394). I'll stop after this
as this seems to be a fundamental issue in the whole temporal modules
suite:
t.rast.extract input=pluies_nc output=tempmean_2010 where="start_time >=
'2010-01-01' and start_time < '2011-01-01'"
File "/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-
gnu/scripts/t.rast.extract", line 106, in <module>
main()
gnu/scripts/t.rast.extract", line 100, in main
base, time_suffix, nprocs, register_null)
gnu/etc/python/grass/temporal/extract.py", line 189, in extract_dataset
gscript.overwrite())
gnu/etc/python/grass/temporal/open_stds.py", line 174, in open_new_stds
sp.insert(dbif)
gnu/etc/python/grass/temporal/abstract_space_time_dataset.py", line 378,
in insert
statement += AbstractDataset.insert(self, dbif=dbif, execute=False)
gnu/etc/python/grass/temporal/abstract_dataset.py", line 398, in insert
statement += self.metadata.get_insert_statement_mogrified(dbif)
gnu/etc/python/grass/temporal/base.py", line 401, in
mapset=self.mapset)
gnu/etc/python/grass/temporal/core.py", line 945, in mogrify_sql_statement
return self.connections[mapset].mogrify_sql_statement(content)
gnu/etc/python/grass/temporal/core.py", line 1215, in
str(args[count]),
UnicodeEncodeError: 'ascii' codec can't encode character u'\xe9' in
position 2: ordinal not in range(128)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3395>
