[GRASS-dev] [GRASS GIS] #3397: db.select - reading multiline SQL statements from file fails
trac at osgeo.org
Fri Aug 11 03:17:56 PDT 2017
Reporter: maitl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.0
Component: Database | Version: 7.2.1
Resolution: | Keywords: db.select, db.execute
CPU: Unspecified | Platform: All
Changes (by mlennert):
* milestone: 7.2.2 => 7.4.0
Comment:
Replying to [ticket:3397 maitl]:
> It is convenient to store longer SQL statements into file.
> If each statement is not exactly one line in input file, then db.select
ends with error.
This is due to the fact that db.select reads the input file line by line,
and then uses all text before a semi-colon as the SQL statement.
This means that with a file test.sql that contains
SELECT count(*) FROM boundary_county WHERE Z_MEAN > 38;
SELECT count(*) FROM boundary_county;
you get
count(*)
333
count(*)
926
while if the file contains
SELECT count(*) FROM boundary_county WHERE Z_MEAN > 38; SELECT count(*)
you only get
count(*)
333
The same happens when you do this:
echo "SELECT count(*) FROM boundary_county WHERE Z_MEAN > 38; SELECT
count(*) FROM boundary_county;" | db.select input=-
and I cannot integrate a newline ('\n') character:
echo "SELECT count(*) FROM boundary_county WHERE Z_MEAN > 38\n; SELECT
DBMI-SQLite erreur de pilote :
Error in sqlite3_prepare():
SELECT count(*) FROM boundary_county WHERE Z_MEAN > 38\n; SELECT count(*)
unrecognized token: "\"
A rewrite of this to more flexibly parse the SQL, be it with one statement
over several lines, or several statements on one line would be nice, but I
would consider this too invasive to go into 7.2.2.
So, I propose that for 7.2.2 we just amend the manual. I've taken the
liberty to add one sentence about that in trunk and release72 (r71389 and
r71390).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3397#comment:2>
