[GRASS-dev] [GRASS GIS] #3392: t.register: encoding error
trac at osgeo.org
Fri Aug 11 06:28:12 PDT 2017
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Temporal | Version: svn-trunk
Resolution: | Keywords: t.register encoding
CPU: Unspecified | Platform: Unspecified
Comment (by zarch):
Replying to [comment:4 mlennert]:
> Replying to [comment:2 zarch]:
> > So I think that instead of returning unicode as I did in the first
patch we should return bytes...
> > Please apply the two diff files, and let me know if it is working for
you.
> I've applied your patches (BTW: it is always best to make diffs relative
to the source tree root. That way one doesn't have to search for where the
patched files are...).
Ops, sorry I did not notice that the diff was sensitive to my current
working directory.
> t.info (#3394) and t.rast.extract (#3395) now work, but I suspect that
the errors there came from the accent in the description of the strds.
Indeed the error was due to `é` character in the description. I was able
to reproduce only the error with `t.info`. I added a test r71391.
I'm not able to reproduce these errors in: `t.create`, `t.register`,
`t.unregister`, `t.remove`.
I executed the testsuite in `grass/lib/python/temporal` and
`grass/temporal` with no regressions.
But, since I was able to reproduce only the `t.info` error, it would be
nice, before do the commit, to add tests in: t.create, t.register,
t.unregister, t.remove that problem.
At the moment I'm not able to write the tests for them, someone can help
me?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3392#comment:5>
