[GRASS-dev] [GRASS GIS] #3399: installing addons with g.extension fails on windows
trac at osgeo.org
Fri Aug 11 15:43:57 PDT 2017
Reporter: baharmon | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Addons | Version: unspecified
Keywords: | CPU: x86-64
Platform: Unspecified |
GRASS 7.2.1 64 bit on Windows 10 g.extension fails to install addons for
me. I've tried r.geomorphon, r.skyview, & r.stream.distance.
g.extension extension=r.geomorphon operation=add
Downloading precompiled GRASS Addons <r.geomorphon>...
File "C:\Program Files\GRASS GIS
7.2.1/scripts/g.extension.py", line 1733, in <module>
sys.exit(main())
7.2.1/scripts/g.extension.py", line 1712, in main
install_extension(source=source, url=url, xmlurl=xmlurl)
7.2.1/scripts/g.extension.py", line 680, in
install_extension
ret += install_extension_win(module)
7.2.1/scripts/g.extension.py", line 953, in
outdev=outdev, directory=srcdir, tmpdir=TMPDIR)
7.2.1/scripts/g.extension.py", line 1094, in
download_source_code
f, h = urlretrieve(url, zip_name)
7.2.1\Python27\lib\urllib.py", line 94, in urlretrieve
return _urlopener.retrieve(url, filename, reporthook,
data)
7.2.1\Python27\lib\urllib.py", line 240, in retrieve
fp = self.open(url, data)
7.2.1\Python27\lib\urllib.py", line 208, in open
return getattr(self, name)(url)
7.2.1\Python27\lib\urllib.py", line 345, in open_http
h.endheaders(data)
7.2.1\Python27\lib\httplib.py", line 969, in endheaders
self._send_output(message_body)
7.2.1\Python27\lib\httplib.py", line 829, in _send_output
self.send(msg)
7.2.1\Python27\lib\httplib.py", line 791, in send
self.connect()
7.2.1\Python27\lib\httplib.py", line 772, in connect
self.timeout, self.source_address)
7.2.1\Python27\lib\socket.py", line 553, in
create_connection
for res in getaddrinfo(host, port, 0, SOCK_STREAM):
IOError: [Errno socket error] [Errno 11002] getaddrinfo
failed
(Fri Aug 11 17:41:48 2017) Command finished (10 sec)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3399>
