[GRASS-dev] [GRASS GIS] #3392: t.register: encoding error
trac at osgeo.org
Sat Aug 12 07:59:19 PDT 2017
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Temporal | Version: svn-trunk
Resolution: | Keywords: t.register encoding
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:10 huhabla]:
> Replying to [comment:9 mlennert]:
> > Maybe the solution needs to be found in lib/python/pygrass/messages ?
> Good point. I have tried to fix this issue and attached the
"pygrass_temporal_gis_utf_handling.diff" that must be applied to fresh
trunk.
> Can you please test the changes?
They don't seem to work:
t.create output=tempmean type=strds temporaltype=absolute title="Average
temperature" description="Monthly temperature average in NC [deg C]"
Process Process-1:
File "/usr/lib/python2.7/multiprocessing/process.py", line 258, in
_bootstrap
self.run()
File "/usr/lib/python2.7/multiprocessing/process.py", line 114, in run
self._target(*self._args, **self._kwargs)
File "/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-
gnu/etc/python/grass/pygrass/messages/__init__.py", line 95, in
message_server
libgis.G_verbose_message(message.encode("utf-8"))
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 2:
ordinal not in range(128)
and, even worse:
t.register -i input=tempmean type=raster start=2000-01-01 increment="1
months" file=rasters_tempmean.list
Collecte des informations sur la carte ...
Process Process-1:
_bootstrap
self.run()
gnu/etc/python/grass/pygrass/messages/__init__.py", line 93, in
message_server
libgis.G_debug(level, message.encode("utf-8"))
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 1:
ATTENTION: Needed to restart the messenger server
Process Process-3:
_bootstrap
self.run()
message_server
Process Process-4:
_bootstrap
self.run()
message_server
I'm also not sure whether using u' strings is the solution, nor how
portable this is between Python 2 and 3. Anna should probably have a look
at this as she has quite some experience with the encoding issues...
>I am not able to convince my GRASS installation to use the German locale
that i have set, so its a kind of dry test.
You can use the GUI: Settings->Preferences->Appearance->Language settings.
However: looking at grasslibs_de.po I have the feeling that most temporal
lib strings have not been translated to German, yet. Maybe these strings
have only recently been translated to French, making the errors appear now
Ticket URL: <https://trac.osgeo.org/grass/ticket/3392#comment:11>
