[GRASS-dev] Dockerfile now in repo
Markus Neteler
neteler at osgeo.org
Tue Aug 15 05:31:51 PDT 2017
On Sat, Jul 29, 2017 at 6:15 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Hi all,
> I just added a Dockerfile to the Subversion repository. The Dockerfile uses
> the local source code, i.e. typically what you get with svn, because it is a
> part of the source code. It it not downloading any GRASS GIS source code by
> itself, so you can make changes in the source code locally and rebuild the
> image (you need to tell Docker to remove the existing image (layer) or to
> not use cache).
> It is using Ubuntu, but something more lightweight may be more appropriate,
> some other images, on the other hand, may bring some additional features. It
> is not installing any GRASS addons or using PPA repositories.
> The documentation is in the README (yes, we have a README file ;-). I hope
> it is the right place. It contains example which runs all the tests. It
> assumes you have NC SPM location on your (local) disk.
> The image keeps the source code (the source code is not removed) and it has
> one volume which you mount and that's where the data are supposed to be.
Now available on docker hub:
docker pull neteler/grassgis7
Markus
