[GRASS-dev] t.rast.mapcalc with same substring dataset names
Michel Wortmann wortmann at pik-potsdam.de
Tue Aug 15 06:14:23 PDT 2017
Hi dev team,
I have been trying to run a few t.rast.mapcalc operations and
encountered the substring dataset name problem described here:
http://trac.osgeo.org/grass/ticket/2735
To my understanding this has never actually been fixed, so I tried to
come up with a fool-proof solution. To prevent successive substitution
of substrings, the dataset names in the expression are first filled with
random string identifiers in descending string length order that can
later be "formated" with exp.format(). See diff attached. This might be
useful for other t.* modules that use the exp.replace() approach.
Since I havent got the latest trunk compiled, I wasnt able to test it in
grass, but the concept should work. Would be great if someone with more
t.* experience than me could test it.
Best regards,
Michel
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170815/f908623f/attachment-0001.bin>
