[GRASS-dev] [GRASS GIS] #3402: g.gui.gmodeler: trying to add command pushes CPU to 100% and provokes freeze
trac at osgeo.org
Fri Aug 18 09:28:46 PDT 2017
freeze
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.2.2
Component: wxGUI | Version: svn-trunk
Keywords: gmodeler freeze | CPU: Unspecified
Platform: Unspecified |
Trying to add a module call ("Add command") to the modeler leads to 100%
CPU usage and a freeze of the modeler, before the module addition window
content is visible.
I can add data and loops and I can load an existing model and access the
module dialogs, but I cannot add a new module call.
I've tried with trunk, release72, 7.2.1 and release70, all cause the same
problem, so I imagine that it probably has to do with some changes in
relevant external libraries, not in the gmodeler code itself, but I don't
know how to debug this.
I'm on Debian testing, so python-wx 3.0.2.0 and python 2.7.
Can anyone confirm this issue ? It makes the modeler absolutely useless to
me, so I classify this as major, although it only concerns this particular
module.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3402>
