[GRASS-dev] New attempt to update GRASS for Mac
Michael Barton
Michael.Barton at asu.edu
Sat Aug 19 14:38:50 PDT 2017
Markus and Eric,
I have not had a chance to try these things out because of the chaos of the beginning of semester. That's why I'd hoped to get further along when in Boulder. Once things calm down next week (I hope), I'll try these out.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Aug 19, 2017, at 9:15 AM, Markus Neteler <neteler at osgeo.org<mailto:neteler at osgeo.org>> wrote:
Hi Michael,
On Wed, Aug 16, 2017 at 12:10 AM, Eric Hutton <hutton.eric at gmail.com<mailto:hutton.eric at gmail.com>> wrote:
Hi Michael
It's hard for me to say without seeing which tests are failing but I think
at least some of those errors are probably due to DYLD_LIBRARY_PATH not
being set correctly. As far as I can tell, when grass is being tested during
the make process the tests are run within an environment that has the
necessary environment variables set (PATH, DYLD_LIBRARY_PATH, GISRC, etc. -
this is the run_grass command defined in Rules.make). It seems that the
tests are run in a new environment that doesn't inherit your
DYLD_LIBRARY_PATH (even if you've exported it). It seems like this might a
bug? I'm not certain.
To fix some of these errors I manually added $PREFIX/lib to
DYLD_LIBRARY_PATH for the run_grass command. I did this in Rules.make (line
40, for me),
$(LD_LIBRARY_PATH_VAR)="$(BIN):$(GISBASE)/bin:$(GISBASE)/scripts:$(ARCH_LIBD
IR):$(BASE_LIBDIR):$(PREFIX)/lib:$($(LD_LIBRARY_PATH_VAR))"
Or have a look at the attached patch file. Note that for me all of my
dependencies were installed in $PREFIX/lib.
Eric
Did Eric's patch actually help?
Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170819/a1e23d88/attachment.html>
