[GRASS-dev] [GRASS GIS] #3392: t.register: encoding error
trac at osgeo.org
Sun Aug 20 14:59:36 PDT 2017
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Temporal | Version: svn-trunk
Resolution: | Keywords: t.register encoding
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:27 annakrat]:
> Does t.unregister work for you if you don't specify mapset in the strds
name?
t.unregister input=tempmean file=rasters_tempmean.list
Unregister maps
100%
Unregister maps from space time dataset <tempmean>
So, yes, it worked, with or without your latest commit.
> I committed the fix above.
Duh. I was focused on lib/python/temporal and completely forgot to check
the modules for gisenv() calls. Sorry, just too many other things on the
platter these days. Thanks for catching this.
> I think this should go to the release. But we will need to come back to
this and rethink it to enable Python3. I unfortunately don't know yet what
needs to be done for that, I will look at Pietro's changes.
Ok. I'll try to find time tomorrow to merge it all into release72.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3392#comment:28>
