[GRASS-dev] [GRASS GIS] #3402: g.gui.gmodeler: trying to add command pushes CPU to 100% and provokes freeze
trac at osgeo.org
Sun Aug 20 15:36:12 PDT 2017
freeze
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.2.2
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: gmodeler freeze
CPU: Unspecified | Platform: Unspecified
Comment (by annakrat):
what does this give you?
import wx
wx.version()
I have '3.0.2.0 gtk2 (classic)'. I just want to make sure it's GTK3, the
'3' in your packages might refer to wxpython 3, not gtk 3.
You can test example OGL in wxpython demo, I suspect there could be a
problem related to this. If the problem is in the dialog, you could try to
remove certain widgets and see if the problem persists. I see it creates a
long list of modules in the wx.Choice widget, maybe that could an issue?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3402#comment:4>
