[GRASS-dev] [GRASS GIS] #3405: encoding issue when launching modules (was: g.search.modules: 'ascii' codec can't encode character u'\xe0' in position 11: ordinal not in range(128))
GRASS GIS trac at osgeo.org
Mon Aug 21 09:40:41 PDT 2017
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.2.2
 Component:  wxGUI        |    Version:  svn-trunk
Resolution:               |   Keywords:  g.search.modules encoding
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mlennert):
 Apparently this is a larger issue:
 i.segment --ui
   File "/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-
 gnu/gui/wxpython/gui_core/forms.py", line 2995, in <module>
     task.get_cmd(ignoreErrors=True, ignoreRequired=True))
 gnu/etc/python/grass/script/task.py", line 248, in get_cmd
     errList = self.get_cmd_error()
 gnu/etc/python/grass/script/task.py", line 208, in get_cmd_error
     {'name': p['name'], 'desc': encode(desc)})
 gnu/etc/python/grass/script/utils.py", line 217, in encode
     return bytes(string)
 UnicodeEncodeError: 'ascii' codec can't encode character u'\xe9' in
 position 29: ordinal not in range(128)
 v.lrs.create --ui
 position 36: ordinal not in range(128)
 r.surf.idw --ui
 position 35: ordinal not in range(128)
 Interestingly, for all these modules no GUI window is created
 automatically if they are launched without '--ui' from the command line. I
 have the feeling this is new.
 When I launch the modules from the GUI menu, I get a window with the error
 message, but clicking 'OK' lets me use the module normally.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3405#comment:1>
