[GRASS-dev] [GRASS GIS] #3402: g.gui.gmodeler: trying to add command pushes CPU to 100% and provokes freeze
GRASS GIS trac at osgeo.org
Wed Aug 23 03:11:50 PDT 2017
freeze
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  major        |  Milestone:  7.2.2
 Component:  wxGUI        |    Version:  svn-trunk
Resolution:               |   Keywords:  gmodeler freeze
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mlennert):
 Replying to [comment:8 mlennert]:
 > However, I think I found the culprit: the tooltip ! Disabling it makes
 the widget work again:
 > Index: gui/wxpython/gmodeler/dialogs.py
 > --- gui/wxpython/gmodeler/dialogs.py  (révision 71430)
 > +++ gui/wxpython/gmodeler/dialogs.py  (copie de travail)
 > @@ -203,7 +203,7 @@
 >              lambda command: self.label.SetValue(command))
 >          self.search = SearchModuleWidget(parent=self.panel,
 >                                           model=menuModel.GetModel(),
 > -                                         showTip=True)
 > +                                         showTip=False)
 >          self.search.moduleSelected.connect(
 >              lambda name: self.cmd_prompt.SetTextAndFocus(name + ' '))
 >          wx.CallAfter(self.cmd_prompt.SetFocus)
 Just to confirm, I tried add showTip=True to the call to the same widget
 in gui/wxpython/gui_core/menu.py and it creates the same kind of issue,
 only that now the entire GUI freezes as soon as I call g.gui...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3402#comment:9>
