[GRASS-dev] [GRASS GIS] #3407: v.in.ogr fails to import ESRI Shapefile with empty attribute table cells
GRASS GIS trac at osgeo.org
Wed Aug 23 09:57:21 PDT 2017
  Reporter:  mikatt   |      Owner:  grass-dev@…
      Type:  defect   |     Status:  new
  Priority:  normal   |  Milestone:
 Component:  Default  |    Version:  7.2.1
Resolution:           |   Keywords:
       CPU:  x86-64   |   Platform:  Linux
Comment (by mmetz):
 Replying to [ticket:3407 mikatt]:
 > GRASS 7.2.1 (on Linux Mint 18) produces an error when trying to read in
 ESRI shapefiles that have empty cells. This used to work fine until
 recently, and I have no problems with GRASS 7.2.0 on Windows 7.
 What are the GDAL/OGR versions?
 > Here is a minimal example including messages:
 Thanks for the example, I could reproduce the error.
 > Have there been substantial changes to v.in.ogr or could this be a
 RGDAL/OGR issue?
 This is a GDAL/OGR issue. As of GDAL 2.2, `OGR_F_IsFieldSet()` apparently
 returns true even if the field is empty, and `OGR_F_GetFieldAsString()`
 returns a zero-length string (not NULL) for an empty field.
 v.in.ogr has been fixed in r71431,2 (trunk, relbr72) to account for the
 new behaviour of GDAL 2.2, supporting older versions of GDAL.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3407#comment:1>
