[GRASS-dev] [GRASS GIS] #3407: v.in.ogr fails to import ESRI Shapefile with empty attribute table cells
trac at osgeo.org
Wed Aug 23 12:08:54 PDT 2017
Reporter: mikatt | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.2.1
Resolution: | Keywords:
CPU: x86-64 | Platform: Linux
Comment (by mmetz):
Replying to [comment:6 rouault]:
> > Regarding export from GRASS to OGR, what happens if a field is not
explicitly set or unset? Is it now unset or set, but NULL? Do we need to
adjust v.out.ogr using `OGR_F_SetFieldNull()` and/or `OGR_F_UnsetField()`
instead of not touching the field at all?
> By default and by definition, a field that is not set ... is unset :-)
This is no different in GDAL 2.2 than in previous versions. So depending
on drivers, they might react differently on writing if a field is unset or
if it set to an empty string. For CSV and Shapefile, this will result in
the same file. For GeoJSON, a unset field doesn't appear at all in the
result, whereas an empty string is written as '"field" : "" '
Ok, a field that is not set is unset or set, but NULL, depending on the
driver ;-)
> With GDAL 2.2, you can also set a field to NULL. The behaviour will
depend on drivers. For CSV and Shapefile, NULL will be dealt as unset or
empty string. For GeoJSON, it will be written as ' "field": null '.
From [https://svn.osgeo.org/gdal/branches/2.2/gdal/MIGRATION_GUIDE.TXT]:
"before, a unset field was written as field_name: null. Starting with GDAL
2.2, only fields explicitly set as null with OGR_F_SetFieldNull() will be
written with a null value."
In order to preserve backwards compatibility for other software packages,
GRASS will need to use OGR_F_SetFieldNull() starting with GDAL 2.2 if data
export should not change.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3407#comment:7>
