[GRASS-dev] v.in.osm working?
Markus Metz
markus.metz.giswork at gmail.com
Thu Aug 24 00:30:22 PDT 2017
On Tue, Aug 22, 2017 at 8:37 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi,
> does v.in.osm actually work? I am trying to import from a OSM PBF
> file, for example:
> http://download.geofabrik.de/europe/germany/berlin.html
> --> berlin-latest.osm.pbf (51MB)
> grass72 ~/grassdata/latlong_wgs84/osm
> g.extension v.in.osm
> v.in.osm input=Downloads/berlin-latest.osm.pbf table=lines
> type=point,line output=roads --o
> WARNING: Width for column osm_id set to 255 (was not specified by OGR),
> some strings may be truncated!
> WARNING: Width for column name set to 255 (was not specified by OGR), some
> WARNING: Width for column highway set to 255 (was not specified by OGR),
> WARNING: Width for column waterway set to 255 (was not specified by OGR),
> WARNING: Width for column aerialway set to 255 (was not specified by OGR),
> WARNING: Width for column barrier set to 255 (was not specified by OGR),
> WARNING: Width for column man_made set to 255 (was not specified by OGR),
> WARNING: Width for column other_tags set to 255 (was not specified by
OGR),
> WARNING: Vector map <roads> already exists and will be overwritten
> WARNING: No data base element files found
> v.info -t roads
> nodes=0
> points=0
> lines=0
> boundaries=0
> centroids=0
> areas=0
> islands=0
> primitives=0
> map3d=0
You can use v.in.ogr directly for OSM PBF files (
http://gdal.org/drv_osm.html).
BTW, with GDAL 2.2.1, using OGR_INTERLEAVED_READING=YES does not work for
me (empty vector).
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170824/26ee2928/attachment.html>
