[GRASS-dev] [GRASS GIS] #3409: d.what.vect JSON issue with OSM data
trac at osgeo.org
Thu Aug 24 01:37:37 PDT 2017
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Display | Version: svn-releasebranch72
Keywords: d.what.vect, v.what | CPU: x86-64
Platform: Linux |
I have imported successfully an OSM pbf file, can display it but not
query:
ScriptError(_("v.what output is not valid JSON format:
(screenshot attached since the error cannot be copy-pasted, no text
selection possible)
To reproduce:
# (51MB)
wget http://download.geofabrik.de/europe/germany/berlin-latest.osm.pbf
grass72 -c epsg:4326 ~/grassdata/latlong_wgs84
v.in.ogr input=berlin-latest.osm.pbf type=point,line output=roads
g.region vector=roads -p
d.mon wx0 # same issue with g.gui
d.vect roads
d.what.vect roads
# --> JSON error
Here an example for v.what output not parsable by d.what.vect (note: this
is not exactly the same position as in the error msg screenshot):
v.what roads coordinates=13.3926375553,52.5548668929 -a
East: 13:23:33.495199E
North: 52:33:17.520814N
Map: roads
Mapset: osm
Type: Point
Layer: 1
Category: 34721
Driver: sqlite
Database: /home/mneteler/grassdata/latlong_wgs84/osm/sqlite/sqlite.db
Table: roads_1
Key column: cat
cat : 34721
osm_id : 631984925
name :
barrier :
highway :
ref :
address :
is_in :
place :
man_made :
other_tags : "addr:city"=>"Berlin","addr:street"=>"Bornholmer
Straße","addr:suburb"=>"Gesundbrunnen","addr:country"=>"DE","addr:postcode"=>"13359","addr:housenumber"=>"50"
Some more "escaping" might be needed here?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3409>
