[GRASS-dev] [GRASS GIS] #3405: encoding issue when launching modules
GRASS GIS trac at osgeo.org
Thu Aug 24 03:31:42 PDT 2017
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.4.0
 Component:  wxGUI        |    Version:  svn-trunk
Resolution:               |   Keywords:  g.search.modules encoding
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mlennert):
 I'm completely stumped on this one: my office and home machine both run
 Debian testing. I recompiled a fresh svn trunk checkout from scratch
 (r71433). I moved the .grass7 directories to avoid any cruft. locale
 settings are equal between the two. In neither do I have special
 characters anywhere in the gisenv paths.
 Result: on the home machine I get the above errors, on the office machine
 I don't.
 Setting LANGUAGE=C allows the module GUI to launch without an error on my
 home machine. The only difference I see is that on the office machine
 LANGUAGE=C and the launching the module does not give any messages in the
 terminal, while on the home machine, the same combination gives me:
 (forms.py:26034): Gtk-WARNING **: Unable to locate theme engine in
 module_path: "adwaita",
 Could that be the issue ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3405#comment:4>
