[GRASS-dev] [GRASS GIS] #3409: d.what.vect JSON issue with OSM data
trac at osgeo.org
Thu Aug 24 06:48:01 PDT 2017
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Display | Version: svn-releasebranch72
Resolution: | Keywords: d.what.vect, v.what
CPU: x86-64 | Platform: Linux
Comment (by mmetz):
Replying to [ticket:3409 neteler]:
> I have imported successfully an OSM pbf file, can display it but not
query:
> Here an example for v.what output not parsable by d.what.vect (note:
this is not exactly the same position as in the error msg screenshot):
> v.what roads coordinates=13.3926375553,52.5548668929 -a
> East: 13:23:33.495199E
> North: 52:33:17.520814N
> Map: roads
> Mapset: osm
> Type: Point
> Layer: 1
> Category: 34721
> Driver: sqlite
> Database: /home/mneteler/grassdata/latlong_wgs84/osm/sqlite/sqlite.db
> Table: roads_1
> Key column: cat
> cat : 34721
> osm_id : 631984925
> name :
> barrier :
> highway :
> ref :
> address :
> is_in :
> place :
> man_made :
> other_tags : "addr:city"=>"Berlin","addr:street"=>"Bornholmer
Straße","addr:suburb"=>"Gesundbrunnen","addr:country"=>"DE","addr:postcode"=>"13359","addr:housenumber"=>"50"
> Some more "escaping" might be needed here?
Alternatively you can use a osmconf.ini file
[http://gdal.org/drv_osm.html] to 1) avoid the creation of the other_tags
field, 2) select some of the OSM keys summarized in the other_tags field.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3409#comment:1>
