[GRASS-dev] [GRASS GIS] #3405: encoding issue when launching modules
trac at osgeo.org
Thu Aug 24 07:52:47 PDT 2017
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.0
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: g.search.modules encoding
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:8 mlennert]:
> Bingo ! I found the problem. At the top of lib/python/script/utils.py,
there is this:
> try:
> from builtins import unicode
> except ImportError:
> # python3
> unicode = str
> However, in order to be able to import builtins I have to install the
package python-future which was not the case on my home computer. Does
this mean we assume this to be a dependence ?
> This said, if I just comment out this part of the code, I do not get the
errors either, as apparently the decode function works as is with the
builtin unicode type in python 2.
> Anna, could you enlighten me why this import from future is necessary ?
And if it is, we will have to make this an official dependence...
Sorry, wrong adressee: I just saw that Pietro introduced this just
recently. Will contact him.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3405#comment:9>
