[GRASS-dev] python script utils encoding/decoding overriding unicode with python-future
Pietro peter.zamb at gmail.com
Fri Aug 25 08:06:03 PDT 2017
Unfortunately builtins is used also in other files, and I’m afraid
that I should also fix these:
$ rg "builtins" . -B 1 -A 5
script/task.py
24-try:
25:    from builtins import unicode
26-    bytes = str
27-except ImportError:
28-    # python3
29-    unicode = str
30-
temporal/core.py
38-try:
39:    from builtins import long
40-except ImportError:
41-    # python3
42-    long = int
43-
44-from .c_libraries_interface import *
script/vector.py
27-    # python3
28:    import builtins as __builtin__
29-    unicode = str
30-
31-from .utils import parse_key_val
32-from .core import *
33-from grass.exceptions import CalledModuleError
script/temporal_script_utils_encoding.diff
10-+try:
11:+    from builtins import unicode
12-+except ImportError:
13-+    # python3
14-+    unicode = str
15-+
16-+
script/raster.py
31-try:
32:    from builtins import unicode
33-    bytes = str
34-except ImportError:
35-    # python3
36-    unicode = str
37-
gunittest/utils.py
59-    except ImportError:
60:        import builtins as __builtin__
61-    __builtin__._ = new_translator
62-
63-
64-_MAX_LENGTH = 80
65-
pygrass/vector/table.py
13-try:
14:    from builtins import long, unicode
15-except ImportError:
16-    # python3
17-    long = int
18-    unicode = str
19-
script/core.py
43-    # python3
44:    import builtins as __builtin__
45-    from os import environb as environ
46-    unicode = str
47-__builtin__.__dict__['_'] = __builtin__.__dict__['_'].__self__.lgettext
48-
49-
ctypes/OBJ.x86_64-pc-linux-gnu/temporal.py
13-try:
16-    long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/cluster.py
13-try:
16-    long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/ogsf.py
13-try:
16-    long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/proj.py
13-try:
16-    long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/vector.py
13-try:
16-    long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/stats.py
13-try:
16-    long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/arraystats.py
13-try:
16-    long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/vedit.py
13-try:
16-    long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/rowio.py
13-try:
16-    long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/display.py
13-try:
16-    long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/date.py
13-try:
16-    long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/raster3d.py
13-try:
16-    long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/segment.py
13-try:
16-    long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/gis.py
13-try:
16-    long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/nviz.py
13-try:
16-    long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/gmath.py
13-try:
16-    long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/rtree.py
13-try:
16-    long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/raster.py
13-try:
16-    long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/dbmi.py
13-try:
16-    long = int
17-
18-import os
19-import sys
ctypes/OBJ.x86_64-pc-linux-gnu/imagery.py
13-try:
16-    long = int
17-
18-import os
19-import sys
ctypes_pregit/ctypesgencore/processor/operations.py
97-def fix_conflicting_names(data, opts):
98:    """If any descriptions from the C code would overwrite Python builtins or
99-    other important names, fix_conflicting_names() adds underscores
to resolve
100-    the name conflict."""
101-
102-    # This is the order of priority for names
103-    descriptions = data.functions + data.variables + data.structs + \
124-        important_names[name] = "a name needed by ctypes or ctypesgen"
125:    for name in dir(__builtins__):
126-        important_names[name] = "a Python builtin"
127-    for name in opts.other_known_names:
128-        important_names[name] = "a name from an included Python module"
129-    for name in keyword.kwlist:
130-        important_names[name] = "a Python keyword"
ctypes/ctypesgencore/printer/preamble.py
1-try:
2:    from builtins import long
3-except ImportError:
4-    long = int
5-
6-import os
7-import sys
ctypes/ctypesgencore/parser/lex.py
31-try:
32:    from builtins import bytes
33-    PY3 = True
35-    # python2
36-    bytes = str
37-    PY3 = False
ctypes/ctypesgencore/parser/cgrammar.py
13-try:
16-    # python3
17-    long = int
18-
19-__docformat__ = 'restructuredtext'
ctypes/ctypesgencore/processor/operations.py
to resolve
101-
pygrass/vector/testsuite/test_table.py
7-try:
8:    from builtins import long
9-except ImportError:
10-    # python3
11-    long = int
12-
13-import os
25-try:
26:    from builtins import long
28-    long = int
29-
30-# dictionary that generate random data
31-COL2VALS = {'INT': lambda n:     np.random.randint(9, size=n),
ctypes/ctypesgencore/parser/pplexer.py
13-try:
15-    PY2 = True
16-except ImportError:
17-    # python3
18-    PY2 = False
19-    long = int
