[GRASS-dev] [GRASS GIS] #3402: g.gui.gmodeler: trying to add command pushes CPU to 100% and provokes freeze
GRASS GIS trac at osgeo.org
Fri Aug 25 08:39:00 PDT 2017
freeze
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  major        |  Milestone:  7.2.2
 Component:  wxGUI        |    Version:  svn-trunk
Resolution:               |   Keywords:  gmodeler freeze
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by annakrat):
 It takes short description of the module and display is using
 StaticWrapText which is defined in widgets.py. I suspect that widget is
 the problem, it runs into some infinite loop, could you test, where
 exactly is it stuck?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3402#comment:11>
