[GRASS-dev] [GRASS GIS] #3402: g.gui.gmodeler: trying to add command pushes CPU to 100% and provokes freeze
GRASS GIS trac at osgeo.org
Fri Aug 25 09:22:41 PDT 2017
freeze
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  major        |  Milestone:  7.2.2
 Component:  wxGUI        |    Version:  svn-trunk
Resolution:               |   Keywords:  gmodeler freeze
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mlennert):
 Replying to [comment:12 annakrat]:
 > Try this if it helps:
 > Index: gui_core/widgets.py
 > --- gui_core/widgets.py       (revision 71422)
 > +++ gui_core/widgets.py       (working copy)
 > @@ -1087,7 +1087,7 @@
 >          self._search.Bind(wx.EVT_TEXT_ENTER, self.OnEnter)
 >          if self._showTip:
 > -            self._searchTip = StaticWrapText(parent=self, id=wx.ID_ANY,
 > +            self._searchTip = wx.StaticText(parent=self, id=wx.ID_ANY,
 >                                               size=(-1, 35))
 >          if self._showChoice:
 > @@ -1160,6 +1160,7 @@
 >          label = _("%d modules match") % len(commands)
 >          if self._showTip:
 >              self._searchTip.SetLabel(label)
 > +            self._searchTip.Wrap(self.GetSize()[0])
 >          self.showNotification.emit(message=label)
 > @@ -1193,6 +1194,7 @@
 >              for module in self._results:
 >                  if cmd == module.data['command']:
 self._searchTip.SetLabel(module.data['description'])
 >                      break
 It does ! Everything seems to work fine with this patch applied.
 Thanks, once again, Anna !
 How much risk we break something in applying this, including to release72
Ticket URL: <https://trac.osgeo.org/grass/ticket/3402#comment:13>
