[GRASS-dev] [GRASS GIS] #3392: t.register: encoding error
trac at osgeo.org
Mon Aug 28 13:36:59 PDT 2017
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Temporal | Version: svn-trunk
Resolution: | Keywords: t.register encoding
CPU: Unspecified | Platform: Unspecified
Comment (by annakrat):
Replying to [comment:30 glynn]:
> Replying to [comment:12 annakrat]:
> > The problem mostly comes from calling gisenv function from
script.utils which returns unicode.
> That shouldn't be the case. Nothing in the grass.script module should
ever return unicode. Because if it does, anything which isn't wxgui will
just have to turn it back into bytes again. Which is more error-prone than
just leaving it as bytes in the first place.
Since r65787 script.gisenv() returns unicode, because of Python3 support
as the commit message says. We need to have a discussion about Python3 and
what should be the strategy to make the code compatible.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3392#comment:31>
