[GRASS-dev] [GRASS GIS] #2875: Python testsuite failing with UnicodeDecodeError
trac at osgeo.org
Thu Aug 31 05:45:07 PDT 2017
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Tests | Version: svn-trunk
Resolution: | Keywords:
CPU: Unspecified | Platform: Linux
Comment (by mlennert):
Sorry, had forgotten about this ticket. Thanks Maris for closing the
other.
Coming back to the debate concerning localization of the testing suite. I
don't think that the output of the testing suite has to be localized, but
I actually notice that a series of tests fail because the messages from
the tested modules, but others because the testing is based on C-locale
output of the module (e.g. g.remove).
I think it would be great to be able to run the entire test suite in any
locale. This would allow more systematic testing of locale related issues
in modules. I don't think that the outputs of the testsuite have to be
localized, but errors arise because of the handling of module error
messages by the testsuite:
python test_r_mapcalc.py
.E
ERROR: test_seed_required (__main__.TestRandFunction)
Test that seed is required when rand() is used
File "test_r_mapcalc.py", line 99, in test_seed_required
self.assertModuleFail('r.mapcalc', expression='rand_x = rand(1, 200)')
File "/data/home/mlennert/SRC/GRASS/grass-7.2.2RC2/dist.x86_64-pc-linux-
gnu/etc/python/grass/gunittest/case.py", line 1180, in assertModuleFail
module.run()
gnu/etc/python/grass/pygrass/modules/interface/module.py", line 716, in
run
module=self.name, errors=stderr)
gnu/etc/python/grass/exceptions/__init__.py", line 71, in __init__
msg += _(". See the following errors:\n%s") % errors
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 37:
ordinal not in range(128)
Ran 10 tests in 0.983s
FAILED (errors=1)
Running the same test with LANGUAGE=C gives me:
LANGUAGE=C;python test_r_mapcalc.py
ERROR: Pseudo-random number generator not seeded
Ran 10 tests in 1.014s
OK
IIUC, the difference comes from this:
LANGUAGE=fr_BE;r.mapcalc expression='rand_x = rand(1, 200)'
ERREUR :Générateur de nombres pseudo-aléatoires sans graine
GRASS 7.2.2RC2
(nc_spm_08):/data/home/mlennert/SRC/GRASS/grass-7.2.2RC2/raster/r.mapcalc/testsuite
> LANGUAGE=C;r.mapcalc expression='rand_x = rand(1, 200)'
Ticket URL: <https://trac.osgeo.org/grass/ticket/2875#comment:12>
