[GRASS-dev] [GRASS GIS] #3461: STVDS and libgis error on OS X
trac at osgeo.org
Sun Dec 3 09:09:33 PST 2017
Reporter: mankoff | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: LibGIS | Version: 7.2.2
Keywords: temporal, stvds | CPU: OSX/Intel
Platform: MacOSX |
I'm able to create STRDS on OS X, but STVDS aren't working. Following the
example here:
https://grasswiki.osgeo.org/wiki/Temporal_data_processing/seasonal_aggregation
the `t.register` command fails, with the following error:
> t.register type=vector input=points file=seasonal_points.txt
Gathering map information...
WARNING:root:Needed to restart the libgis server, caller: Server check
thread
ERROR: Exception raised: [Errno 9] Bad file descriptor Message:
read_vector_info
This occurs on OS X with GRASS 7.2 installed via Fink or MacPorts. It does
not happen on Linux, leading me to believe this is an OS X specific bug.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3461>
