[GRASS-dev] [GRASS GIS] #3461: STVDS and libgis error on OS X
GRASS GIS trac at osgeo.org
Tue Dec 5 02:39:24 PST 2017
  Reporter:  mankoff    |      Owner:  grass-dev@…
      Type:  defect     |     Status:  new
  Priority:  normal     |  Milestone:
 Component:  LibGIS     |    Version:  7.2.2
Resolution:             |   Keywords:  temporal, stvds
       CPU:  OSX/Intel  |   Platform:  MacOSX
Comment (by mankoff):
 I apologize - it appears I can run these tests. They do not require
 *compiling* the source.
 I have some output, but don't know what to do with it.
 From the terminal, I have:
 > $GRASS_PYTHON -m grass.gunittest.main --location nc_spm_08_grass7
 --location-type nc
 test_dbcolumns from ./db/db.columns failed (1 test failed)
 test_dbcopy from ./db/db.copy failed (4 tests failed)
 test_dbdescribe from ./db/db.describe failed (2 tests failed)
 toolboxes from ./gui/wxpython/core failed
 gis_lib_str_color from ./lib/gis failed (14 tests failed)
 test_assertions from ./lib/python/gunittest failed (4 tests failed)
 test_assertions_vect from ./lib/python/gunittest failed (6 tests failed)
 test_doctests from ./lib/python/pygrass failed (1 test failed)
 test_doctests from ./lib/python/pygrass/gis failed (1 test failed)
 test_history from ./lib/python/pygrass/raster failed (1 test failed)
 test_doctests from ./lib/python/pygrass/rpc failed
 test_doctests from ./lib/python/pygrass/vector failed
 test_geometry from ./lib/python/pygrass/vector failed
 test_geometry_attrs from ./lib/python/pygrass/vector failed
 test_vector from ./lib/python/pygrass/vector failed
 test_vector3d from ./lib/python/pygrass/vector failed
 test_utils from ./lib/python/script failed (12 tests failed)
 test_doctests from ./lib/python/temporal failed (11 tests failed)
 etc...
 I'm getting a lot of dialogs popping up alerting me that `Python quit
 unexpectedly`. And I have the HTML test results in
 `/testreport/testfiles.html`.
 Where should I dig deeper?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3461#comment:3>
