[GRASS-dev] Testing the new ZSTD raster compression - was: Re: GRASS GIS raster files: LZW compression?
Helmut Kudrnovsky hellik at web.de
Fri Dec 8 10:30:39 PST 2017
Markus Neteler wrote
> Hi,
> (subject renamed for clarity, original thread:
> part 1:
> https://lists.osgeo.org/pipermail/grass-dev/2017-October/thread.html#86395
> part 2:
> https://lists.osgeo.org/pipermail/grass-dev/2017-December/086738.html
after little testing, I succeed to compile winGRASS with ZSTD-support ;-)
Fri Dec 8 19:10:32 CET 2017: STARTING dll.to.a
/c/OSGeo4W64/bin/libzstd.dll => mswindows/osgeo4w/lib/libzstd
 * [C:/OSGeo4W64/bin/libzstd.dll] Found PE+ image
checking host system type... x86_64-w64-mingw32
checking for gcc... gcc
checking whether to use zstd... yes
checking for location of zstd includes...
checking for zstd.h... yes
checking for location of zstd library...
checking for ZSTD_compress in -lzstd... yes
GRASS is now configured for:  x86_64-w64-mingw32
  Source directory:           /usr/src/grass_trunk
  Build directory:            /usr/src/grass_trunk
  Installation directory:     ${prefix}/grass-7.5.svn
  Startup script in directory:/c/OSGeo4W64/bin
  C compiler:                 gcc -g -O2
  C++ compiler:               c++ -g -O2
  Building shared libraries:  yes
  OpenGL platform:            Windows
  MacOSX application:         no
  MacOSX architectures:
  MacOSX SDK:
  BLAS support:               no
  BZIP2 support:              yes
  C++ support:                yes
  Cairo support:              yes
  DWG support:                no
  FFTW support:               yes
  FreeType support:           yes
  GDAL support:               yes
  GEOS support:               yes
  LAPACK support:             no
  Large File support (LFS):   yes
  libLAS support:             yes
  MySQL support:              no
  NetCDF support:             no
  NLS support:                yes
  ODBC support:               yes
  OGR support:                yes
  OpenCL support:             no
  OpenGL support:             yes
  OpenMP support:             no
  PDAL support:               no
  PNG support:                yes
  POSIX thread support:       no
  PostgreSQL support:         yes
  Readline support:           no
  Regex support:              yes
  SQLite support:             yes
  TIFF support:               yes
  X11 support:                no
  Zstandard support:          yes <=
steps:
- compiled zstd-1.3.2 in MSYS2 (other possibility would be to use the
precompiled zstd-binaries from the zstd project)
- added manually exe and dll and the header of zstd to the OSGeo4W-tree
- adapted grass_trunk\mswindows\osgeo4w\package.sh
that's all.
all what would be needed is to include zstd into the OSGeo4W tree. will open
a ticket there.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
