[GRASS-dev] [GRASS GIS] #3464: winGRASS compilation: Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:144: Syntax error at 'va_list'
trac at osgeo.org
Fri Dec 8 13:19:42 PST 2017
'va_list'
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.0
Component: Compiling | Version: svn-releasebranch74
Resolution: | Keywords:
CPU: All | Platform: MSWindows 8
Comment (by neteler):
The error seems to be here:
Replying to [ticket:3464 hellik]:
> Status: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64
> -I/c/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include
-D__GLIBC_HAVE_LONG_LONG
> -U __GNUC__ -dD "-Dinline=" "-D__inline__=" "-D__extension__="
"-D_Bool=uint8_t"
> "-D__const=const" "-D__asm__(x)=" "-D__asm(x)=" "-DCTYPESGEN=1"
> c:/users/landa/appdata/local/temp/tmpwjeiup.h
> Error: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64
> -D__GLIBC_HAVE_LONG_LONG: In file included from
C:/msys64/mingw64/x86_64-w64-mingw32/include/_mingw.h:275:0,
> Error:
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/defs/gis.h:157:
> Status: Processing description list.
> Error: Typedef "__time64_t" depends on an unknown typedef "__int64".
Typedef "__time64_t" will not be output
> Error: Struct "_stat64" depends on an unknown typedef "__int64". Struct
"_stat64" will not be output
Some related discussion:
https://lists.osgeo.org/pipermail/grass-dev/2017-November/086585.html
Apparently more ifdefs are needed...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3464#comment:1>
