[GRASS-dev] Windows compilation failed
CM Reddy
chalamcharla at hotmail.com
Tue Dec 12 08:39:11 PST 2017
Hi All,
I tried to install Grass source on Windows 10 using the following link.
https://trac.osgeo.org/grass/wiki/CompileOnWindows
Downloaded the GRASS source from development trunk using the following commands.
cd /usr/src
On Compilation , it failed with following errors.
<FINAL ERROR>
Started compilation: Tue Dec 12 12:47:54 IST 2017
Errors in:
/usr/src/grass_trunk/raster/r.in.lidar
/usr/src/grass_trunk/raster3d/r3.in.lidar
/usr/src/grass_trunk/vector/v.out.lidar
/usr/src/grass_trunk/vector/v.in.lidar
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
</FINAL ERROR>
On running the make in r.in.lidar directory. it failed with following error.
<RASTER ERROR>
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/bin/r.in.lidar.exe: error while loading shared libraries: libgrass_raster.7.5.svn.dll: cannot open shared object file: No such file or directory
make: *** [../../include/Make/Html.make:14: r.in.lidar.tmp.html] Error 1
</RASTOR ERROR>
I have also noticed many related to header files in package.log file. Please find the some of the errors for your reference.
<HEADER_ERRORS>
Status: Preprocessing c:/users/work/appdata/local/temp/tmpgupeez.h
Status: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64 -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -D__GLIBC_HAVE_LONG_LONG -U __GNUC__ -dD "-Dinline=" "-D__inline__=" "-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)=" "-D__asm(x)=" "-DCTYPESGEN=1" c:/users/work/appdata/local/temp/tmpgupeez.h
Error: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64 -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -D__GLIBC_HAVE_LONG_LONG: In file included from C:/msys64/mingw64/x86_64-w64-mingw32/include/_mingw.h:275:0,
Error: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64 -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -D__GLIBC_HAVE_LONG_LONG: from C:/msys64/mingw64/x86_64-w64-mingw32/include/crtdefs.h:10,
Error: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64 -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -D__GLIBC_HAVE_LONG_LONG: from C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:9,
Error: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64 -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -D__GLIBC_HAVE_LONG_LONG: from C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/gis.h:24,
Error: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64 -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -D__GLIBC_HAVE_LONG_LONG: from c:/users/work/appdata/local/temp/tmpgupeez.h:1:
Error: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64 -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -D__GLIBC_HAVE_LONG_LONG: C:/msys64/mingw64/x86_64-w64-mingw32/include/vadefs.h:35:2: error: #error VARARGS not implemented for this compiler
Error: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64 -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -D__GLIBC_HAVE_LONG_LONG: #error VARARGS not implemented for this compiler
Error: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64 -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -D__GLIBC_HAVE_LONG_LONG: ^~~~~
Status: Parsing c:/users/work/appdata/local/temp/tmpgupeez.h
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:176: Syntax error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:182: Syntax error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:188: Syntax error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:193: Syntax error at 'va_list
</HEADER_ERRORS>
Please help us in resolving the above errors.
- Thanks
CM Reddy
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171212/fc40bf28/attachment.html>
