[GRASS-dev] how difficult would it be to modify i.edge to not load the entire image into memory ?
Moritz Lennert
mlennert at club.worldonline.be
Thu Dec 14 02:47:59 PST 2017
On 14/12/17 05:45, Vaclav Petras wrote:
> Hi Moritz,
> I'm currently at AGU
Enjoy ! :-)
> and can't dig into the code, but yes, I think it
> can be rewritten with segment library, preferably with MarkusM's
> "segment or in-memory" wrapper.
Great ! Markus, is this wrapper in the library, or just in existing
modules ? I know the version in the i.superpixels.slic addon and have
some memory of you implementing it elsewhere.
Moritz
> Vaclav
> On Tue, Dec 12, 2017 at 10:51 AM, Moritz Lennert
> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>> wrote:
> Hi Anna, Hi Vaclav,
> I would love to use the i.edge module. However, the fact that it
> reads everything into memory obviously limits its use either to
> small images, or to tiled versions of larger images.
> I have just rapidly looked at the code, but I cannot really detect
> any place where you really need the entire image, or ? The Gaussian
> filter could be cut off at a certain distance and the actual Canny
> detector is also based on a kernel, AFAICT. So, do you think this
> could be rewritten to use the SEGMENT library and at all times only
> load necessary parts of the image into memory ?
> Moritz
