[GRASS-dev] [GRASS GIS] #3462: Allow setting environment variables in grass startup script
trac at osgeo.org
Sat Dec 16 03:41:06 PST 2017
Reporter: mankoff | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: major | Milestone:
Component: Default | Version: 7.2.2
Resolution: | Keywords:
CPU: Unspecified | Platform: MacOSX
Comment (by mankoff):
My shell is `/bin/bash`.
I have the following in `~/.grass.bashrc`:
echo ".grass.bashrc"
export FOO=42
export DYLD_LIBRARY_PATH=/opt/local/share/grass-7.2.2/lib
And this in `~/.grass7/bashrc`:
echo ".grass7/bashrc"
export BAR=42
And when I launch grass with: `grass72 -c ./Gtmp`, I see the following:
.grass.bashrc
.grass7/bashrc
And:
GRASS 7.2.2 (Gtmp):~ > echo $FOO
GRASS 7.2.2 (Gtmp):~ > echo $BAR
42
GRASS 7.2.2 (Gtmp):~ > echo $DYLD_LIBRARY_PATH
If I comment out the line that blocks `export` statements in my startup
file, both `FOO` and `DYLD_LIBRARY_PATH` are correctly set. Is the `DYLD`
issue related to the following? What is going on on line 564:
https://trac.osgeo.org/grass/browser/grass/trunk/lib/init/grass.py?rev=65585#L564
# Set LD_LIBRARY_PATH (etc) to find GRASS shared libraries
# this works for subprocesses but won't affect the current process
path_prepend(gpath("lib"), ld_library_path_var)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3462#comment:6>
