[GRASS-dev] pip install grass-session - No matching distribution found for grass-session
Markus Neteler
neteler at osgeo.org
Sun Dec 17 05:44:25 PST 2017
Hi Pietro, all,
with joy I have seen the new "grass-session" magic in the Wiki.
I tried to install it but
Collecting grass-session
Could not find a version that satisfies the requirement
grass-session (from versions: )
With strace I see
write(1, "Collecting grass-session\n", 25) = 25
stat("/home/mneteler/tmp/pip-build-hTGeiS", {st_mode=S_IFDIR|0700,
st_size=4096, ...}) = 0
stat("/home/mneteler/tmp/pip-build-hTGeiS/grass-session/setup.py",
0x7ffd283bcb30) = -1 ENOENT (No such file or directory)
stat("https://pypi.python.org/simple/grass-session/", 0x7ffd283bc3b0)
Checking the web site:
--> Not Found (grass-session does not exist)
Is there another trick needed?
thanks
Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171217/0908a3ce/attachment.html>
