[GRASS-dev] [GRASS-PSC] GRASS add-on sharing and write access
Moritz Lennert mlennert at club.worldonline.be
Mon Dec 18 00:21:45 PST 2017
[CC'ing grass-dev where such discussion should be happening]
On 17/12/17 22:37, Markus Neteler wrote:
> On Sun, Dec 17, 2017 at 9:14 PM, Markus Metz
> <markus.metz.giswork at gmail.com> wrote:
>> Right now, r.drain is somewhat overloaded: it creates directions for a DEM
>> same way r.fill.dir does it, or it uses supplied directions, then the module
>> extracts least costly paths. I suggest to have a new module r.path that
>> extracts extract least costly paths from input directions and start points
>> and mark r.drain as deprecated.
> Sounds interesting! At time it is a bit confusing.
+1
Moritz
