[GRASS-dev] pip install grass-session - No matching distribution found for grass-session
Pietro peter.zamb at gmail.com
Mon Dec 18 13:38:26 PST 2017
Hi Markus,
On Sun, Dec 17, 2017 at 5:11 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Ah, just discovered the trick:
> https://grasswiki.osgeo.org/w/index.php?title=Working_with_
> GRASS_without_starting_it_explicitly&diff=0&oldid=24906
> Now it works fine.
Sorry if I didn't replied to you, but I thought that the "best" reply was
fix the missing information on the wikipage.
Thank you to pointing out the missing information, it is still under
testing on my side.
I'm going to test and use for an analyses in the next weeks, after this I
would like to publish it on pypi, and therefore should be installable with
"pip install grass-session".
Hopefully for the beginning of the next year.
Today, I found out: https://github.com/perrygeo/mower that it seems
similar, my approach should be more flexible for multiprocessing (this is
my impression).
If it works well for my use case, I will publish it on pypi, and I will
write to grass-user.
Thank you for your interest.
Have a nice night.
All the best.
Pietro
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171218/e17b6cc9/attachment.html>
