[GRASS-dev] [GRASS GIS] #3462: Allow setting environment variables in grass startup script
trac at osgeo.org
Tue Dec 19 03:28:37 PST 2017
Reporter: mankoff | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: major | Milestone:
Component: Default | Version: 7.2.2
Resolution: | Keywords:
CPU: Unspecified | Platform: MacOSX
Comment (by martinl):
Replying to [comment:10 mankoff]:
> I get that as mentioned earlier, environment variables should be loaded
by `load_env()`. But nobody has offered an explanation for why `export`
statements are ignored here. GRASS is,
Well, then it's up to you to help us discovering where the problem is.
Nobody else was able till now to reproduce this bug. Than it's hard to
guess.
> generally, a power user tool and lets the users do what they want. Why
is it acting in such a protective manner here?
Instead of hacking around it would be nice to find out why `load_env()` is
not working in your case.
> $ GRASS_DEBUG=ON grass72 -c EPSG:3413 ./Gtmp
> DEBUG: GRASS_DEBUG environmental variable is set. It is meant to be an
internal variable for debugging only this script.
> Use 'g.gisenv set="DEBUG=[0-5]"' to turn GRASS GIS debug mode on if you
wish to do so.
> DEBUG: Environmental variable set BAR=42
DYLD_LIBRARY_PATH=/opt/local/share/grass-7.2.2/lib
Looks OK.
> .grass.bashrc
> .grass7/bashrc
Such lines are not printed in my case.
> GRASS 7.2.2 (Gtmp):~ > env | grep BAR
> BAR=42
> GRASS 7.2.2 (Gtmp):~ > env | grep DY
Please attach your `.grass7/bashrc` file.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3462#comment:11>
