[GRASS-dev] [GRASS GIS] #3468: r.drain: replace with new r.path, support multiple directions
trac at osgeo.org
Wed Dec 20 11:32:27 PST 2017
Reporter: mmetz | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.5.0
Component: Raster | Version: svn-releasebranch74
Resolution: | Keywords: r.drain
CPU: All | Platform: All
Comment (by wenzeslaus):
Replying to [ticket:3468 mmetz]:
> A new module r.path could be added that uses a direction map with
optional surface map to trace paths. r.drain could then be converted to a
script calling r.path. If no direction map is supplied, r.fill.dir can be
used by r.drain to create a direction map.
Sounds good. Similar to the case of r.grow and r.grow.distance (and
replacing what is now r.grow.shrink in addons).
Once r.drain is a script, it would be great if we can manage to also
remove the need for providing a "dummy" cost map. See `r.mapcalc "const1 =
1"` in a r.drain example I created recently (please, correct me if I'm
wrong):
https://grass.osgeo.org/grass74/manuals/r.drain.html#path-following-
directions
> r.fill.dir uses a bitmask to encode multiple directions from a single
cell, as described by Jenson and Domingue (1988). These multiple
directions are internally resolved to find the main (single) flow
direction which is then recoded to a standard direction format using
degrees. This bitmask to encode multiple directions from a single cell
could be used and exposed by various other modules,
This makes sense to me also in light of what I have recently dealt with in
r71809 (null values if conversion fails). We are potentially throwing out
information and this was partially related to the fact that until recently
it was hiding some potential problems in r.fill.dir (the problems are
still there, just not as hidden as before).
Jenson and Domingue (1988) is a format described in a paper and it makes
sense adding it. Any ideas for a name? The current ones (in r.fill.dir)
are not really descriptive (agnps, answers, grass).
> i.e. r.cost, r.walk, r.watershed, to be used as input for r.path.
One common format for all modules would be great. It is strange when user
needs to recompute the angles like in my r.drain example from above
(again, correct me if I'm wrong):
directions
> the least costly path from a single start point to a single stop point
can split and merge repeatedly (see attached multiple-directions-
path.png).
Looks great!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3468#comment:2>
