[GRASS-dev] [GRASS GIS] #3469: i.atcorr: Sentinel-2 support broken on some systems
trac at osgeo.org
Thu Dec 21 01:48:30 PST 2017
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.0
Component: Packaging | Version: unspecified
Resolution: | Keywords: i.atcorr
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
I'm on Debian testing with gcc (Debian 7.2.0-17) 7.2.1 20171205.
Using fresh trunk with the following compiler settings:
CFLAGS="-g -Wall -fopenmp -lgomp -Ofast -fno-fast-math
-march=core-avx-i -fno-common -fexceptions $PENTIUM64"
LDFLAGS="-Wl,--no-undefined -fopenmp -lgomp"
CXXFLAGS="-g -Ofast"
and applying the exact commands given in this ticket, I get as result:
r.info -r test_atcorr
min=NULL
max=NULL
Several questions:
* In the discussion in the mailing list, some examples were with i.atcorr
-r, others without. Do we agree that in this case it should be with -r as
the data contains reflectance information ?
* What is the exact meaning and impact of the range setting ?
* Stefan, any special reason why you import your data with '-o' ? Why not
create an EPSG 32633 location and import the data there ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469#comment:1>
