[GRASS-dev] [GRASS GIS] #3469: i.atcorr: Sentinel-2 support broken on some systems
trac at osgeo.org
Thu Dec 21 01:56:15 PST 2017
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.0
Component: Packaging | Version: unspecified
Resolution: | Keywords: i.atcorr
CPU: Unspecified | Platform: Unspecified
Comment (by sbl):
Replying to [comment:1 mlennert]:
> Several questions:
> * In the discussion in the mailing list, some examples were with
i.atcorr -r, others without. Do we agree that in this case it should be
with -r as the data contains reflectance information ?
Yes, I would say so.
> * Stefan, any special reason why you import your data with '-o' ? Why
not create an EPSG 32633 location and import the data there ?
Laziness ;-): We usually treat 32633 and 25833 as identical (max
difference in Norway is reported to be ~40cm). So, I just did not want to
create a new location for testing with Sajids data...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469#comment:3>
