[GRASS-dev] [GRASS GIS] #3469: i.atcorr: Sentinel-2 support broken on some systems
GRASS GIS trac at osgeo.org
Fri Dec 22 01:12:31 PST 2017
  Reporter:  sbl          |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.4.0
 Component:  Packaging    |    Version:  unspecified
Resolution:               |   Keywords:  i.atcorr
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mmetz):
 Replying to [comment:12 sbl]:
 > Yes, thanks so much Markus!
 > With the patch i.atcorr gives now also numbers on Ubuntu 14.04:
 > min = 0  max = 8514
 > So results are identical to Moritz`s.
 > I noticed that although "rescale" option was set to be 0-10000, maximum
 output was 8514...\\
 With
 i.atcorr -r input=B08 elevation=dem range=0,10000 output=test_atcorr
 rescale=0,10000 parameters=p6s.txt
 I get
 min=8.736016e-10
 max=10000
 on Fedora 27
 and
 min=8.708314e-10
 max=10000
 on Debian testing (Buster)
 So there is some non-NULL output, but it differs between systems. Not so
 nice.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3469#comment:13>
