[GRASS-dev] [GRASS GIS] #3468: r.drain: replace with new r.path, support multiple directions
trac at osgeo.org
Fri Dec 22 12:06:26 PST 2017
Reporter: mmetz | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.5.0
Component: Raster | Version: svn-releasebranch74
Resolution: | Keywords: r.drain
CPU: All | Platform: All
Comment (by mmetz):
Replying to [comment:5 mmetz]:
> Replying to [comment:4 wenzeslaus]:
> > Replying to [comment:3 mmetz]:
> > > That would be a substantial change because other modules (all
r.stream.*) depend on the direction output of r.watershed.
> > Then I guess we have 3 standards and all make sense. Should all the
modules have flags, or perhaps an option as r.fill.dir, to set the desired
direction encoding/format?
> Right now, I have introduced a new -b flag, but that only makes sense if
there are 2 possible formats. For more different formats, an option as
r.fill.dir would make sense.
I have removed the -b flag and added an option to define the format of the
input direction map in r71967.
> Instead of changing lots of existing modules, r.path could be enhanced
to support more different direction formats, e.g. r.watershed's
directions.
Supported formats are r.watershed's directions, degrees CCW from east and
bitmask encoded directions. By default, r.path tries to automatically
detect the format of the input direction map.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3468#comment:6>
