[GRASS-dev] using g.mapset in python script
Markus Metz
markus.metz.giswork at gmail.com
Thu Dec 28 12:39:09 PST 2017
On Sun, Dec 24, 2017 at 3:10 PM, Paulo van Breugel <p.vanbreugel at gmail.com>
wrote:
> Hi devs,
> I am trying to create a new mapset and open that mapset using g.mapset.
When doing this from the command line, I can import layers in the new
mapset using r.in.gdal without problems.However, running this in a python
script doesn't work. E.g., when I run:
> gs.run_command("g.mapset", flags="c", mapset="LST",
location="latlon_clark66")
> Next, I try to import a layer:
> infile="lst_01.tif"
> outfile="lst_01"
> gs.run_command("r.in.gdal", input=infile, output=outfile)
> This gives me the error:
> gs.run_command("r.in.gdal", input="lst_01.tif", output="lst_01")
> Traceback (most recent call last):
> File "<ipython-input-18-2c415e16d79f>", line 1, in <module>
> File "/usr/local/grass7/grass-7.5.svn/etc/python/grass/script/core.py",
line 421, in run_command
> return handle_errors(returncode, returncode, args, kwargs)
line 332, in handle_errors
> returncode=returncode)
> CalledModuleError: Module run None ['r.in.gdal', 'input=lst_01.tif',
'output=lst_01'] ended with error
> Process ended with non-zero return code 1. See errors in the (error)
output.
> Any idea why this doesn't work?
It is a pity that the output to stderr is not available when a module is
called in python with gs.run_command() and the module fails. The python
traceback is in this case useless. Maybe handle_errors() [0] could be
improved to also provide the stderr output of the current module.
Markus M
[0]
https://trac.osgeo.org/grass/browser/grass/trunk/lib/python/script/core.py#L318
> Best wishes,
> Paulo
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20171228/cca5b1a7/attachment.html>
