[GRASS-dev] [GRASS GIS] #2764: corrupt data written to FCELL and DCELL rasters, hard to re-produce
trac at osgeo.org
Sun Dec 31 00:15:51 PST 2017
Reporter: dylan | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.3
Component: Raster | Version: unspecified
Resolution: | Keywords:
CPU: x86-64 | Platform: Linux
Comment (by mmetz):
Replying to [comment:9 dylan]:
> After applying the patch, I see this (more informative) error message:
> Decompression failed with error 0
The actual error code is missing, the patch was wrong, now updated.
Which compressor are you using?
> This was in the context of a corrupt (?) map generated by r.horizon,
when run in parallel like this:
> seq 0 $step 330 | parallel --gnu --progress "bash make-hz-maps.sh {}
$step $elev"
> make-hz-makes.sh is a simple wrapper around r.horizon:
> # start angle
> start=$1
> # angle step size
> step=$2
> # elevation map
> map=$3
> # r.horizon requires start, step, and end angles
> # compute end angle via bc
> end=`echo "$start + $step" | bc`
> r.horizon --q --o elevation=$map step=$step start=$start end=$end
output=hzangle
> Am I abusing GRASS raster libraries by invocation of multiple instances
of the same module that all access the same elevation map?
I don't think so, multiple instances of the same module should run
independent of each other. The problem could be anywhere between the
physical hard drive having problems with multiple simultaneous requests to
read the same file, the OS handling such requests, and the GRASS file
reading mechanism.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2764#comment:10>
