[GRASS-dev] Still Failing: GRASS-GIS/grass-ci#1909 (master - 05df514)
Vaclav Petras wenzeslaus at gmail.com
Sat Feb 4 09:37:35 PST 2017
On Sat, Feb 4, 2017 at 8:48 AM, Yann <dr.yann.chemin at gmail.com> wrote:
> Is Travis doing OK ?
Sorry for the noise. The Mac compilation had 3rd party dependencies and
other issues, see e.g.
https://trac.osgeo.org/grass/ticket/3250
I committed
https://trac.osgeo.org/grass/changeset/70483
which revers the Mac part of
https://trac.osgeo.org/grass/changeset/68652
The following commit also un-hides the scripts which are in the .travis dir.
https://trac.osgeo.org/grass/changeset/70484
We can consider renaming .travis dir to travis only. But I think
.travis.yml must have exactly this name.
Rainer, I added you to the GRASS GIS org on GitHub, you should be able to
transfer the ownership of the Homebrew repo if you decide to do so in order
to give more people direct access to that code. I suggest using Travis cron
job which can be setup in Travis if one have access to the repo.
https://docs.travis-ci.com/user/cron-jobs/
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170204/0db2dc86/attachment.html>
