[GRASS-dev] Still Failing: GRASS-GIS/grass-ci#1898 (master - 7fa0125)
Rainer M Krug Rainer at krugs.de
Sun Feb 5 23:52:28 PST 2017
Markus Neteler <neteler at osgeo.org> writes:
> On Thu, Feb 2, 2017 at 11:03 AM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Mon, Jan 30, 2017 at 11:20 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>>> Daily build of the Homebrew formula repo seems more appropriate for testing
>>> than the workaround in the code.
>>> Since Travis CI is not 100% reliable for Mac, it will also separate all the
>>> false positives. It still can send messages to grass-dev (all Travis is
>>> already white listed, right?) but more people should get access to the repo
>>> if that's the case.
>> Silly question: why does our Mac script fetch from SVN and not from
>> git? This would solve it.
> Extra question: where is the script actually doing this job?
How do you mean? The script is in the folder .travis (hidden to be
in line with the naming of the .travis.yml file and as it is of no
importance for GRASS itself). There were the scripts (see changeset
https://trac.osgeo.org/grass/changeset/70483 )
Rainer
> Markus
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20170206/6994ed17/attachment.sig>
