[GRASS-dev] [GRASS GIS] #3274: v.net: allow connecting centroids when using option=arcs
GRASS GIS trac at osgeo.org
Mon Feb 6 06:01:08 PST 2017
 Reporter:  mlennert         |      Owner:  grass-dev@…
     Type:  enhancement      |     Status:  new
 Priority:  normal           |  Milestone:  7.4.0
Component:  Vector           |    Version:  unspecified
 Keywords:  v.net centroids  |        CPU:  Unspecified
 Platform:  Unspecified      |
 v.net with option arcs allows to connect pairs of points with lines.
 However it does not allow connecting centroids. From what I can tell the
 following small change would allow this:
 Index: vector/v.net/arcs.c
 --- vector/v.net/arcs.c (révision 70027)
 +++ vector/v.net/arcs.c (copie de travail)
 @@ -80,7 +80,7 @@
         list = Vect_new_list();
      /* find start node */
 -    Vect_cidx_find_all(Pnts, field, GV_POINT, cat, list);
 +    Vect_cidx_find_all(Pnts, field, (GV_POINT | GV_CENTROID) , cat,
 list);
      if (list->n_values < 1) {
         G_warning(_("No point with category %d found"), cat);
         return 0;
 It works for me, but I'm not familiar enough with the module to be sure if
 this is without negative consequences.
 Any objections to committing this ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3274>
